12-13-2005 10:58 AM
12-13-2005 11:02 AM
Continued..... (hit ENTR by mistake)
Those 2 parameters are added only during the runtime. Is this normal? Why does it happens?
Rafi
12-13-2005 02:22 PM
Are you sure you aren't looking at the PreUUT sequence? I have tried to replicate the behavior and have not (using 3.5). Can you give an example of how to reproduce this behavior?
Allen P.
NI
12-14-2005 05:47 AM
12-14-2005 05:54 AM
12-14-2005 09:37 AM
12-14-2005 11:37 AM
Thanks Allen very much
I figured it out. Actually it is something I've done a long time ago. I modified the sequential model so that the main sequence transfer these two parameters. The purpose for that was to get the SN (stored in my StationGlobals) in case the operator selected 'Run selected steps Using SinglePass'.
Do you know of a better way to transfer the SN (UUT.serialNumber) back to the sequential model in this case?
Best Regards
Rafi
