NI TestStand
operator interface statusbar
where is the best place to update the informations (for example station globals) in the statusbar of the (standard full LV) operator interface? The main loop?
greetings
Schwede
(3,005 Views)
Smiley Sad Hello, Smiley Sad
i want to repeat my questions and give some more informations about it:
The assignment is to display the fail/pass count (and other varaibles) from the sql database in the statusbar of the OI window.  And this after every UUT at execution time.
1. I want to get informations (like global variables) from TestStand and receive it with the OI after every UUT at execution time.
Some solution maybe to generate a UIMessage in TestStand (PostUUT/PostUIMessage) and received this with the OI. But how does it work? Example?
2. The really difficulty part is to display this informations in the statusbar of the OI at execution time. Smiley Surprised
thankyou for your help Smiley Very Happy
Schwede
(2,973 Views)
Accepted by Schwede
You can use the Thread.PostUIMessageEx(eventcode = UIMsg_ProgressText, , YourTextParam, , ) method.
The OI will then display your supplied text to the StatusBar of the OI or SeqEditor. You dont have to do anything extra in the OI to handle this.
Hope this helps
Ray Farmer
Ray Farmer
(2,962 Views)
