NI TestStand
notification if report is not written
Sometimes a testtool get disconnected from network while testing.
If so then teststand will not write the HTML report.
Is there a way that teststand will write the report when the connection is restored?
Can I make an message popup when the log file is not written?
Bart
(3,274 Views)
Hi InspectorGadget,
For instances where there is not always a stable connection, but the results still need to be logged, you should be using On-the-fly reporting.
On-the-Fly Report Generation
http://zone.ni.com/reference/en-XX/help/370052N-01/tsreports/infotopics/otf/
Jason H
Automated Test Software R&D
(3,204 Views)
Hello Jason,
Thanks for your reply.
If I set the on the fly report option ON then I still get an error if the path does not exist.
gr,
(3,166 Views)
