NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
juswanto
niRFSA_ReadPowerSpectrumF64 function call in TestStand 4.5.1 cause system error
I am using TestStand with niRFSA.dll to call the function niRFSA_ReadPowerSpectrumF64. This function will make the NI RFSA takes a spectrum sweep and return an array of amplitudes, as well as a structure that contains the frequencies information. My teststand sequence file is attached. The sequence editor will execute this function call, and actually retrieve correct data from the RFSA, I can see all the data in the Locals variables. The data are correct. However, the sequence editor also throws out system error, with no further details.
See the error window also attached.
Once in a while, the sequence editor will work just fine, executing the same function call without throwing out error, this is less than 10% of the time.
I am using this on Windows 7.
Let me know if you have any insight.
Active Participant
snowpunter
Re: niRFSA_ReadPowerSpectrumF64 function call in TestStand 4.5.1 cause system error
You may want to set the Return Value parameter to a variable so that you can look and see if the function is returning an error.
CTA, CLD, MTFBWY
Active Participant
dug9000
[ Edited ]
The most likely explanation is that you either have the function prototype or the struct definition specified incorrectly on the TestStand side. Make sure that the struct doesn't require any special struct packing setting and make sure that you have specified it exactly correct on the teststand side. An incorrect specification can lead to crashes and/or memory corruption like what you are seeing.
Hope this helps,
-Doug
Member
juswanto
Yes I did look at the function return value, its zero or VI_SUCCSESS.
Member
juswanto
Hi Doug:
Yes this is what I suspected also. Since the container type was a TS custom type I created to accept the C struct from the instrument. But when the data come back from the dll is a C struct, and there lays the conflict, I think its the packaging layer semantics have some conflict, even though each of the element in the C struct matches the TS type definitions, as I received all that data correctly in TS.
Juswanto
Active Participant
dug9000
Is there a "#pragma pack" compiler directive in the header file with the structure definition? Did you look at every field in the teststand data type and make sure it matches the struct fields data types? Are you passing the parameter by pointer or by value? Which does the function expect? These are the things to consider as far as whether or not it is being passed correctly.
-Doug
Member
juswanto
Not sure about the pragma pack compiler directive, but I can check it out.
The TS custom container type matches the C structure, and the correct data were passed in correctly from dll structure to TS container.
Active Participant
dug9000
Sometimes the differences are subtle and still look like you are getting the correct data even when it doesn't match exactly. If it is not this though, then the next most likely problem is with the dll itself, or some code that dll is calling.
-Doug
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
