This depends greatly on the format of your Word Document that holds requirements. The default format that Requirements Gateway can read consists of using Styles in Word to determine what is a Requirement and what is the description text of that requirement. This example can be found in the NIRG directory under <NIRG>/examples/Word/. This format can be customized if you are using a different format. However, in order to be parsed, there must be some regular format that can easily be understood by a computer. For more information with using word, the Coupling Document on Word found in the Help is the best place to start.
Allen P.
NI
