11-14-2006 05:42 AM
11-14-2006 03:16 PM
One thread Only is a batch option, so you must using the batch model or it will have no effect.
Failures do not automatically propagate to all sockets because UUTs fail independently. You would have to add steps to force this to happen using a global, a notification, or some other type of cross execution flag or signal.
However, if your step generates an error instead of failing, the error will automatically propagate to all threads when the first thread leaves the batch section. Make sure the step that exits the batch section is in the cleanup group so it will execute despite the error.
11-16-2006 01:26 AM
Many thanks to you
11-16-2006 09:49 AM
11-16-2006 12:47 PM
