09-28-2006 01:29 AM
Hi Ray,
I have to use the DLL setting.I think i should change the dll function.
can you help me in this regard?
Will the custom step type help for this issue?
Radha R
09-28-2006 02:47 AM
I tried using the dll function.But the function (ProcessFlaggedValues) traverse the object continuesly , reads the flag value and updates the report.
I dont know how to change the order of searching. Is there anyother way to achieve this?
regards,
Radha R
09-28-2006 03:00 AM
I think you need to modify ProccessFlaggedSingleValue() -> GetNumberAsFormattedString() in c_report.c
Regards
Ray Farmer
09-29-2006 09:23 AM
I have attached a TS3.5 example of reordering the result string for a NumericLimitTest.
The attached sequence file contains a sequence called ReorderResultText. (if was originally generated in TS2.0 - therefore no Flow Control step Types).
This takes the output of Add Flagged Values, reorders the text and returns the text to be added to the report.
I have included the PutOneResultInReport sequence as example the sequence ReorderResultText has been implemented.
The reordering is basic, it just takes the Measurement line and places it at the end. But you could change this part to suit your needs. A string array holds each line of the Flagged Result text.
I have done it all in TestStand but you could do something similer in C or LabVIEW and would probably be a bit quicker
The more I looked at the GetFlaggedValuesForReport_Txt(), the more I thought of doing an atternate solution.
Hope this is of some help
Regards
Ray Farmer
10-10-2006 02:43 AM
10-10-2006 09:26 AM
hi Ray..
I found the solution for my previous question.. thanks..
Radha
10-10-2006 12:51 PM
