Hi mrbean,
I've not seen this behavior in the past. What version of Visual Studio are you using, is it 6.0 or .NET? Which Measurement Studio CD were you installing when this happened? Make sure if you are using VC 6.0 that you are installing the support for Visual Studio 6. Also, you mention that you think that it still installed correctly. Are you able to run any of the examples that install with Measurement Studio? As I said, this error is not a common issue, so if things are not working correctly for you, I'd recommend reinstalling the software and repost if you get the same errors and we'll investigate further what might be occuring here. Thanks and have a good one.
Adam B.
