I am using the message popup step in TestStand in the beginning of my sequence. I defined 2 buttons - "OK" button and "Cancel" button.
The "OK" button works fine but the "Cancel" button does not function as desired - pressing it still runs the sequence while I want it to cancel or goto the end of the sequence.
All that you've done is define some text for a button. It's without meaning if you don't write some code that handles the actual button pressed. Look at the answer by paul in the post http://forums.ni.com/ni/board/message?board.id=330&message.id=14038. A simple expression to use would be Step.Result.ButtonHit==1?True:False. Then, on the False condition, set the destination to <End>.
