08-09-2013 11:32 AM
On TestStand 4.2.1, I encounter a limit of 6 buttons.
How can I add more buttons ?
Or, can I replace message popup by list ?
Thank you
08-09-2013 03:50 PM
Have you thought of using LabVIEW to create something?
I have attached a simple VI that you can pass an array of string data from TestStand to LabVIEW..
Shane.
08-13-2013 08:01 AM
I am using only TestStand
08-14-2013 09:13 AM
That is unusual. Normally another development environment like LabVIEW, CVI, or .NET is used along with TestStand to interact with intrument drivers and custom code modules. If that is not an option, one idea is to use two message popups, label one of the buttons something like "More Options..." and if that button is pressed, bring up the secondary dialog.
Hope this helps,
-Doug
