07-18-2011 11:22 AM
If you are running this in the a UI or the sequence editor I think I know what the problem might be, the UI or sequence editor will hold onto each execution your create, unless you make them hidden with tracing initially off or set them to close when completed.
1) to make the executions hidden with tracing initially off pass the following two constants bitwise OR'd together for the execution type mask parameter ExecTypeMask_TracingInitiallyOff | ExecTypeMask_InitiallyHidden
2) to make it close when done use the ExecTypeMask_CloseWindowWhenDone constant.
Hope this helps,
-Doug
07-19-2011 07:20 AM
Hi Doug,
I have tried this, it's a bit better. But still not perfect. I have found a thread with a similar issue on LabVIEW, and from several resources I have created a single VI, which cleans up the "WorkingSet" of a process. This works fine.
