08-01-2014 04:16 AM
Hi
I dont want the Operator to see the "Setup Main Cleanup" text while testing
any ideas how to acheive this
In the image as u see the "Setup Main Cleanup" are unwanted info for the Operator
& can confuse. I wasnt able to reduce its size also
the operator only sees the Steps with Large text
08-04-2014 04:25 AM
Hi aparab,
I don't know if's possible to hide the sequence editor itself in the TestStand development system.
If you want to customize the GUI for the operator, it could be usefull to create a custom UI in LabVIEW, .NET ...
Take a look into this document for further information:
Best Practices for NI TestStand User Interface Development - National Instruments
http://www.ni.com/white-paper/7560/en/
Regards, Stephan
08-04-2014 12:28 PM
If you do make a custom GUI, you might want to check out the StepGroupMode property of the SequenceFileViewMgr and ExecutionViewMgr. You can hide the setup and cleanup groups with it by setting it to OneGroup and then unchecking Station Options>>Execution>>Allow Tracing into Setup.Cleanup. However, there is no option to combine the setup, main, and cleanup steps into one list without the step group labels.
