Whenever you create a new execution, it creates a run-time copy of your sequence file to execute. This copies all of the steps and properties and all of the variables (including locals and file globals).
You can share data between executions in several ways. You can use Station Globals. You can use Synchronization Steps to pass data back and forth. You can use the Sequence File option to Share File Globals for every Execution. You can also set the flags on your variables to be Shared or Shared At Run Time.
If you don't want each execution to act indepdently, you won't need to do anything, they each have their own copies of variables. The exception is Station Globals, which are always shared.
Allen P.
NI
