NI TestStand
loading lower version of labview development vi in teststand
I am loading LAbVIEW which is in version  2012 and my system has labVIEW 2013 development engine, but am unable to load 2012 labVIEW VI inTeststand
(3,930 Views)
Hi
1. What error are you seeing? (Move your cursor over the error provider in the Module Tab in Step Settings to see the error).
2. What is your adapter configuration set to? (If it is set to use "LabVIEW Run Time Engine <version>" you must compile all the VIs in LabVIEW you are using.)
or
 You can set the Adapter configuration to use LabVIEW Development System.
You can also refer to http://zone.ni.com/reference/en-XX/help/370052J-01/tsref/infotopics/db_lvadapterconfig/ for more details about Adapter configuration.
(3,927 Views)
