NI Home
Cart Cart | Help
You are here:
Reply
Member
branar
Accepted Solution
list of dll functions
Hi, I've tried to get list of all functions from current dll. Here is my code: tsErrChkMsgPopup( TS_StepGetModule (StepHandle, &errorInfo,&cviModule)); error = TS_CVIModuleAsCommonCModule (cviModule, &errorInfo, &commonCModule); sprintf(sztemp, "c:\\Temp\\%s", szdll); error = TS_CommonCModuleSetModulePath (commonCModule, &errorInfo, sztemp); error = TS_CVIModuleSetModuleType (commonCModule, &errorInfo, TSConst_CVIModuleType_DLL); error=TS_EngineGetAdapter (EngineHandle,&errorInfo, count,&commonCAdapter); error= TS_CommonCAdapterGetDllFunctions (commonCAdapter, &errorInfo, sztemp, &dll_func); Problem was found in the last row. Direct connection between commonCModule and commonCAdapter was not exist, so I ask from EngineHandle for commonCAdapter, because GetDllFunctions exist only for commonCAdapter. Can you help me with this ? best regards, branar
Member
Erik_Crank
Re: list of dll functions
You do not need a module to get a list of DLL functions. Here's some pseudocode for what you need to do:
CommonCAdapter adapter = Engine.GetAdapterByKeyName(AdapterKeyNames.FlexCVIAdapterKeyName);
DllFunctions functions = adapter.GetDllFunctions(path);
for (int i = 0; i < functions.Count; i++)
DllFunction function = functions[i];
string functionName = function.DisplayName;
// Do something with functionName.
Member
branar
Hi Eric,
Thank you for your answer. I was created similar code in CVI with addition that function parameters (if exist) will be writen in txt file. However, number of parameters, for some reason are bigger for one. If function has only two parameters (testData and testError), still anwer is 3. Here is code for this:
error = TS_EngineGetAdapterByKeyName (EngineHandle, &errorInfo, "C/CVI Flexible Prototype Adapter", &commonCAdapter);
error = TS_DllFunctionsGetCount (dll_func, &errorInfo, &count);
max=count;
status=0;
i=0;
count1=0;
while (max>0){
CA_VariantSetInt(&itemIndex,status);
error = TS_DllFunctionsGetItem (dll_func, &errorInfo, itemIndex, &dll_func1);
error = TS_DllFunctionGetDisplayName (dll_func1, &errorInfo, &szStepID);
error = TS_DllFunctionGetHasParameterInformation (dll_func1, &errorInfo, &removedfromCache);
sprintf(buffer,"%s :\n",szStepID);
error = WriteStringToFile (FILE_dll, buffer);
error = TS_CommonCModuleSetFunctionName (commonCModule, &errorInfo,szStepID);
error = TS_ModuleLoadPrototype (commonCModule, &errorInfo, NULL, &removedfromCache);
error = TS_CVIModuleGetParameters (cviModule, &errorInfo, &cviParameters);
error = TS_CVIParametersGetCount (cviParameters, &errorInfo, &count1);
for (i=1;i<count1;i++)
CA_VariantSetInt(&itemIndex,i);
error= TS_CVIParametersGetItem (cviParameters, &errorInfo, itemIndex, &cviParameter);
error = TS_CVIParameterAsCommonCParameter (cviParameter, &errorInfo, &commonCParameter);
error = TS_CommonCParameterGetParameterName (commonCParameter, &errorInfo, &szparam_name);
error = TS_CommonCParameterGetDescription (commonCParameter, &errorInfo, &szparam_desc);
sprintf(buffer,"%s, %s\n",szparam_name,szparam_desc);
CAFREEOBJ (cviParameter);
CAFREEOBJ (commonCParameter);
count1=0;
status++;
max--;
best regards,
branar
Member
Erik_Crank
TestStand treats the function return value as a parameter so the collection of CVIParameters will always contain one more item than the number of function parameters. The return value is the first item in the CVIParameters collection.
Member
branar
Hi Eric,
Thank you for your clarifications.
best regards,
branar
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
