07-29-2014 09:35 AM
I have been using the ivi step for a DMM step in Teststand. When using a NI dmm to read a voltage the ivi steps works ok, but when using a Agilent 34410A DMM it does not give the correct reading back. I have downloaded the 34410a driver from NI and used this rather than the one from Agilent.
Is it the case that the NI_ivi_DMM step only works for a NI dmm and not any other manufacturer?
07-29-2014 09:40 AM
07-30-2014 07:07 AM
Found the problem, the driver session was set to 'Simulate', which resulted in the DMM returning random numbers.
