09-03-2013 10:59 AM
Good Day to all.
Im installing a Test Bench with Windows 7 Embedded Standard (WES7).
First I've build my own light ditribution with the proper drivers for the target machine, an industrial core I3 PC, nothing special to say about it. The Bench is a Stand alone machine, not connected to Internet
Then, I run the setup with the proper switches such as /qb /acceptlicenses yes /disableNotificationCheck
All goes wrong after a certain point, I get the Error 2: issues of compability of the operating system with the Licence Manager
Ouch! that hurts since I have at this point no idea what might be the component of WES7 required to insure the compability.
Any idea is welcome or just tell me if WES7 is Yes/no Compatible with TestStand ????
As a matter of fact, 've got the same issue with DaqMx drivers
Thanks in advance.
09-05-2013 07:11 AM
Hi Xavier,
If you look at this page, you'll see that there is no support for WES7: http://www.ni.com/teststand/product_lifecycle/
It doesn't mean it won't work, just we haven't tested it, and we haven't developed it to work on this OS.
09-06-2013 06:44 AM
Thanks Benoit.
Prior to posting here, I had search the web and found this deceptive information about WES7 and TS.
And the best way to crosscheck my foundings was to ask here.
In the meantime, I had made some progress and I'd like to share it here.
First of all, I succeeded in installing and running both TestStand 2013 and DAQmx 9.8.
I managed to pack these hefty guys in my distribution of WES7, my DVD is 4.2Gb, the setup of the distribution does it all silently (with all the good switches).
Now the inner secret about WES7: under ICE (the configurator), there are several models of distributions. The trick is to go for the 'Application Compatible' model, strip off some fonctionnaliies to tailor to the need and reduce the foot print size.
Then add the the basic drivers, add an $OEM$ folder that contains all the files expanded out from the EXE installer downloaded from NI website.
A bit of fiddling is required but not much and Voila!
I did a few tests on my distribution, all seems to click in all right.
The Test Bench deployed just boots in 30 secs, TestStand becomes operationnal 5 sec later; ideal.
WES7 is just a subset of Windows 7, what to keep, what to remove is the key question in this light distribution.
