09-08-2015 11:08 AM
This works fine for including the step number in the viewer window but how do I get the step number to print out in things like tools>sequence file documentation?
(Step.StepGroup == 0)?(Step.StepIndex):(Step.StepGroup == 1)?(RunState.Sequence.Setup.GetNumElements() + Step.StepIndex):(RunState.Sequence.Setup.GetNumElements() + RunState.Sequence.Main.GetNumElements() + Step.StepIndex)
09-10-2015 04:35 PM
Hi id,
Unfortunately the settings in the Sequence File Documentation are fixed, and likely cannot be altered. You can, however, include the step number in a variable or in a comment in a step, which will show up in the documentation.
02-02-2016 02:20 PM
Any idea what the expression operators were on my prior question before they inserted smiley faces in it? I lost this expression and need to retrieve it...
02-02-2016 04:08 PM
@id wrote:Any idea what the expression operators were on my prior question before they inserted smiley faces in it? I lost this expression and need to retrieve it...
HAHA.... I hate it when it does that. In your case you can replace the smiley faces with a : and ( together. 😞 = : ( without the space
(Step.StepGroup == 0)?(Step.StepIndex): (Step.StepGroup == 1)?(RunState.Sequence.Setup.GetNumElements() + Step.StepIndex): (RunState.Sequence.Setup.GetNumElements() + RunState.Sequence.Main.GetNumElements() + Step.StepIndex)
