06-05-2006 11:09 AM
06-05-2006 11:20 AM
Hi Srini,
Try this example on this link
http://forums.ni.com/ni/board/message?board.id=330&message.id=7873&query.id=21677#M7873
Ray Farmer
06-06-2006 12:25 AM
Parameters.UUT.SerialNumber = Locals.SN1
and
Parameters.ModelData.TestSockets[0].UUT.SerialNumber = Locals.SN1
The above code we tried out using function step in test stand. even we tried out to set SN thru programatically by using the following code
//Sets the Serial Number for the socketId of the current execution
execution.GetThread(0).GetSequenceContext(0,
out frameId).Parameters.SetValString("UUT.SerialNumber", 0, CommonGuiClass.multiBmuSerialNo[socketId]);Thanks in advance
Srini
06-06-2006 12:55 AM
Dear Ray,
Thanks for ur response.
The following code sets the serial number in case of batch execution in the ApplicationManager.StatrtExecution event:
e.exec.GetThread(0).GetSequenceContext(0, out frameId).Parameters.SetValString("TestSocket.UUT.SerialNumber", 0, CommonGuiClass.multiBmuSerialNo[socketId]);
The serial number is getting reflected in the report. But i am not able to fetch the serial number from 'CaptionSource_UUTSerialNumber'. Where should this serial number be assigned alyernatively to retrieve it using 'CaptionSource_UUTSerialNumber'
Thanks and Regards,
MadhuSri
06-06-2006 09:34 AM
Dear Ray
I set the serial number using preUUT callback by the following expression
Parameters.UUT.SerialNumber = FileGlobals.SerialNumber[Parameters.UUT.TestSocketIndex]
where in file globals i have create string array which holds all the UUTs serial numbers( FileGlobals.SerialNumber[])
This works perfectly for TestUUT but when i use single pass it doesn't show me the serial number in the combo box (Execution Change combo box in batch uut). Please tell me the difference between TestUUT - Test Socket Entry Point and TestUUT sequence in Batchmodel. also i have seen the single pass sequence doesn't call the preUUT callback why it is?
Thanks and Regards,
Srini
06-06-2006 10:23 AM
The Single Pass does call the PreUUT, but there is nothing to stop you added this a your own copy of the ProcessModel sequence file which you would place in the User folder.
Ray Farmer
10-24-2012 04:29 AM
I want to restart this topic.
I tried to change the serial number in the header of the xml report. It doesn't work.
I'm using TestStand 2012 f1.
Thank you for help
Sven
