I am using a custom OI for running a burn in test (batch mode)
I would like to write a vi to get the serial numbers and whether or not the slots are enabled
I believe the model uses
PreBatch
Tell Dialog To Get Next UUTs
BUUT_GetNextUUTs
for this purpose
the main problem is that BUUT_GetNextUUTs is not model to the OI and keeps getting stuck behind my OI front panel
if I write a vi to do this I can make it model to the vi
it appears that the modelsupport2.dll interfaces with Parameters.ModelData.DialogHandle
is there a way to do this with a vi?
