NI TestStand
how to pause a execution in a sequence file if any step fails
How can teststand pause a execution if any of the step fails in Sequence file. I used breakpoint settings with RunState.Step.Result.Status == "Failed", But this breakpoint is not worked.. Is there any way to achieve this?
Thanks in advance.
Ran
(3,878 Views)
Accepted by rj_501
add a SequenceFilePostStepFailure and put a statement in there with RunState.Execution.Break().
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,873 Views)
