Benchtop Measurement and Test
High-Performance Test
Systems Engineering Software
09-12-2012 05:23 AM
Hi ,
I need to lock the sequence file from renaming,
actually i have created the sequence call and stored it as the template section with different name.
can you please mention how to lock this sequence call which is there in the template section
04-30-2013 09:36 AM
You can enable the password protection on the sequence file. Go to Edit -> Sequence File Properties -> Advanced. You can password protect the sequence file from any editing unless they have the password.
Thanks!
We'll be in touch soon!
