01-05-2006 02:28 AM
01-05-2006 03:21 AM
I also faced the same problem in my project. I am not sure whether there are any direct methods, but i achieved it through a round about method.
1. Create a Boolean station global
2. Set it to True when you exit the client sequence – as a Last Step in the client sequence clean up tab
3. Modify the process model to continue the clean up only after the Boolean value is True - may be this should be the first step in the process model's clean up tab
4. Don’t forget to initialize the Boolean (Set to false) when starting the test
Hope it helps
Sasi
01-05-2006 09:25 PM
01-06-2006 12:59 AM
Hi Ivan,
In the ProcessModels sequencefile there is a ProcessCleanup sequence that you can override in your sequencefile to ensure that a particular cleanup is performed.
01-09-2006 01:54 AM
Thanks for your kind help,
Ivan
