NI TestStand
how to execute the conditon one after the other
hi,
I would like to know the solution to execute conditons one after the another
Ex..
Set local Variable a = "XXX"
Set local Variable a = "YYY"
Set local Variable a = "ZZZ"
How to execute all the 3 conditions using same local varibale (with different values) should execute in order  i.e. one after the other. Please let me know.
thanks,
chethan
(3,022 Views)
Hey chethan,
Not quite sure I follow what you are going for here.
You can just use 3 statement steps and for each step just set your variable with an expression in each.
Or in a single expression you can separate each expression with a comma.  They will then execute sequentially.
For instance:
Locals.a = "XXX", Locals.a = "YYY", Locals.a = "ZZZ"
I don't understand your brackets and .... in the example of your post.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,019 Views)
Assuming you want to execute different steps...
Use statement step type - locals.a= xxx
step 1
step 2
step 3....
Use statement step - locals.a=yyy
step4
step 5
step 6..
Use statement step - locals.a = zzz
step 7
step 8
step 9
However if your step is common then you can do this :
Create a array a[3] -- fill with xxx, yyy and zzz in that order
Use for each ( iterate over array a)   ( refer examples of how to use for each )
step 1
step 2
step 3....
(3,002 Views)
