02-16-2007 02:02 PM
02-16-2007 02:49 PM
I don't think you would have an event that differs between which entry point was executed. What I think you would need to do is get the event/callback that indicates an executution was started and then get the properties of that exectuion to determine what type/entrypoint it is. For exampe there is a property isInteractive for execution. Try the StartExectuion event callback for the application manager and use a property node inside the callback to get the property of the execution.
Hope this help
02-19-2007 04:33 PM
