06-19-2006 02:35 PM
06-19-2006 02:45 PM
If you are using TestStand 3.5, you can use the MessagePopup step type. Check out the Options tab, enable the Display Image or Web page check box, then you can specify a file or import an image.
Ray Farmer
06-19-2006 02:50 PM
06-19-2006 02:55 PM
Then the only options would be to do it in your code module, and use a picture control.
Use one of the Modal Dialog examples as a starter.
Ray Farmer
06-19-2006 03:06 PM
06-19-2006 03:21 PM
Not sure what language you are using, but for example if you have labview look at Picture Control - Zoom Attribute.vi. Its not a Dialog panel but its shows the use of the picture control. If you are using CVI then there is similar examples.
Ray Farmer
06-19-2006 08:26 PM
