06-13-2006 11:42 PM
06-14-2006 01:09 AM
There is an option in the Preference (I think or it could be the Station Options) that when set, will allow copies the complete callback when you add it to your sequence file rather than an empty version.
Or open the SequentialModel.seq and your test sequence file, select the View All Sequences on both sequence files. Then cut and paste the PreUUT from the SequentialModel.seq to your sequence file. Make sure you dont already have a copy of the callback in your sequence file, otherwise you will get another version called PreUUT_copy.
Hope this helps
Ray Farmer
06-14-2006 12:18 PM
Hi tadk,
Open up your sequential process model (SequentialModel.seq) and then select All Sequences from the View ring control. Next right-click on the PreUUT callback and select Properties. Then select the Model tab and check the Copy Steps and Locals When Creating an Overriding Sequence option.
Hope this helps!
