NI TestStand
how to check string value using if condition
 hi,
I have declared variable A as a string
if(locals.A)!="N/A"
   passs some conditions
else
   fails.
I am getting error at if statment line...pls let me know how to compare the sting value
thanks,
chethan
Message 1 of 9
(6,228 Views)
Locals.a!="N/A"
Put this in the if statement i.e.
if(Locals.a!="N/A")
If this does not   then pls attach sequence.
Message 2 of 9
(6,211 Views)
thanks for your reply....
Sorry i didn't give complete details in previous post....
The requirement is as follows
Parameters.tar_str                    (tar_str is declared as string array under parameter)
Foreachloop
Array to Iterate : Parameters.xxx                                                (xxx is declared as string array)
Current element : locals.Currentelement                                     (Current element is declared as local variable)
Current offset : locals.Currentoffset                                            (Current Offset is decalred as Local variable)
locals.tar_name        (tar_Name is decalred as local string to transfer current offset string of each index)
locals.tar_name = Parameters.tar_str[locals.currentoffset]  -----> here i am getting error as "specified value does not have the expected type. this value will cause run-time error"
Note if i use str(locals.tar_name)== Parameters.tar_str[locals.currentoffset]  --> here i don't get error , so i need to know which statement is correct
if(locals.tar_name!="N/A")
    pass some conditons
else
    fails condition
this is my requirement. Pls let me know the solution
I tried strcmp in if conditon loop but i got error...FYI
Message 3 of 9
(6,206 Views)
Are you trying to use the "If' step type or are you trying to do this in a single expression. If you are trying to do this in a single expression then you need to use the conditional operator '?'.
It's equivalent to how that operator works in C/C++ and it works as follows:
(conditional Expression) ? (Expression to execute if true) : (Expression to execute if false)
-Doug
Message 4 of 9
(6,191 Views)
as I mentioned in previous post, i want to compare using if condition step type not expression.......I would also like to know the solution wherever i am getting error whcih is explianed in my previous post.....Pls let me know.....
Message 5 of 9
(6,183 Views)
Hello Mandya,
Have you seen the TestStand shipping example UsingFlowControlSteps.seq? This example demonstrates in detail how to set up flow control steps. The default location for this example is <TestStand>\Examples\SequenceFlow\.
Please take a look at this example, and adapt your application to fit the If and Else steps shown.
Warm Regards,
Daniel Dorroh
Message 6 of 9
(6,159 Views)
See next post.
Message 7 of 9
(6,150 Views)
regarding:
It sounds like locals.tar_name isn't really a string. If it was a string you would not need to do str().
-Doug
Message 8 of 9
(6,147 Views)
ok..thanks for you reply.....
Message 9 of 9
(6,139 Views)
