NI TestStand
how do I get TS to print Execution Time in header as HH:MM:SS?
I set TS report option to include times
it reports sec
how can I get it as HH:MM:SS?
(2,864 Views)
Hey Stephen,
What kind of report are you generating? XML? HTML?
If it's XML then you will have to change the style sheet to do that format.  Which you will have to know how to do that.
If you are generating using HTML you will have to change the step in the AddReportHeader sequence in the reportgen_html.seq file.  This gets called by the process model.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,847 Views)
txt
(2,840 Views)
