03-22-2006 02:10 PM
03-23-2006 11:19 AM
Hey Stephen,
What kind of report are you generating? XML? HTML?
If it's XML then you will have to change the style sheet to do that format. Which you will have to know how to do that.
If you are generating using HTML you will have to change the step in the AddReportHeader sequence in the reportgen_html.seq file. This gets called by the process model.
03-23-2006 01:03 PM
