NI Home
Cart Cart | Help
You are here:
Reply
Member
vince11
Accepted Solution
how create a DLL with module python?
I am a beginner in TestStand,
I would like to know, how create a DLL with module Python? because for create a sequence, we must own a DLL.
Thank you for your answer
Vincent
Active Participant
Jean-Luc_D.
Re : how create a DLL with module python?
Can you describe more precisely what you want to do ?
You can call a dll made in C/C++ using the code module C/C++ DLL. You can build that kind of dll with LabWindows CVI for example.
Jean-Luc D. NI France
National Instruments France
Journées techniques : du contrôle d'instruments aux bancs de test
Du 4 au 13 juin : Grenoble - Pari...
Member
vince11
I would like use TestStand with Python module. So I believe, we must use a DLL for execute a test, I'm wrong because I can use .exe for realize a test.
Now I know how use TestStand with Python module but I have a mistake. I wonder which is error 255?
Whereas I use .exe in Language C, I have no error.
Thank you for your anwser.
Vincent
Member
vince11
[ Edited ]
I found my answer.
Error caused by the user exit program not being able to load the library file for the executable
I resolved my problem.
Vincent
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
