06-19-2016 07:20 AM
I'm trying to implement custom OI on C#.
What is the proper way to get final result of a sequence (UUT Passed / Failed ) by using TS API ?
P.S. I'm using parallel model.
Thanks in advance.
Solved! Go to Solution.
06-20-2016 06:37 AM
I recommend using/implementing the "UIMsg_ModelState_TestingComplete" callback.
Norbert
06-22-2016 07:31 AM
@airspan wrote:Hi,
Thanks in advance.
You can get Sequnce Result, which is a Result of whole Sequence status
04-21-2020 01:07 AM - edited 04-21-2020 01:36 AM
I got it under UIMsg_ProgressPercent,
if (e.uiMsg.Event == UIMessageCodes.UIMsg_ProgressPercent)
context.Parameters.GetValString("Result.Status", 0);
or under UIMsg_ModelState_TestingComplete,
if (e.uiMsg.Event == UIMessageCodes.UIMsg_ModelState_TestingComplete)
context.Parameters.GetValString("UUTStatus", 0);
