10-20-2005 08:49 AM
10-20-2005 04:19 PM
10-21-2005 12:26 PM
Hi Allen P,
I have one concern using the TestStand API. Suppose, I create an executable file that use the TestStand API to create sequence files and to add steps. (Note that it won't be call from TestStand Sequence Editor). From this executable, I should be able to insert custom step of my type palette.
- Does TestStand is able to insert step without knowledge of the step type inserted? i.e. a kind of step link that will be resolved when the sequence is opened?!?!
- or is it possible to give type palette information to the TS api or TS engine dynamically that will allow the api to add custom step type?
Vincent
10-21-2005 12:57 PM
10-24-2005 06:37 AM
10-24-2005 10:06 AM
10-26-2005 02:45 PM
Vincent,
We are currently investigating the possibility of adding a similar feature looking for into a future version of TestStand. Would you mind if I contacted you (offline, I have your email that you registered with NI) to get some additional information about your use case?
Allen P.
NI
10-27-2005 02:57 AM
Hi Allen P.,
Yes, I'm available for more discussion.
Thanks.
Vincent
