Hi all - I am using the flow step types in TS 3.1 to load values into a local array in the set up routine. The problem I have is that the generated report contains every iteration of this code.
The question is then - can the flow code ( or more generally code written in the setup tab) be inhibited from appearing in the UUT Report.
thanks dht
