This type library for the adapter API is embedded in the teapi.dll. If you are using Visual Studio.NET, there is an attribute called tlbid that you can use with the #import
directive in order to import that embedded library (see the MSDN documentation for more details). For example:
#import tlbid(2)
In VC++ 6.0, there is no way to import embedded type libraries. Therefore, you must use the attached type library file (.tlb) with the #import
directive. For example:
#import "TsAdpApi.tlb"
