04-27-2006 02:48 PM
04-27-2006 03:19 PM
Hey Snood,
Sooo, I'm going to have to go ahead and call shananigans on this one and say that it's more likely a problem with your mouse. The expression field is just going to respond to what the OS is sending it from the mouse. I tried this with my mouse wheel (which can tend to get crazy being that it is wireless) and it worked fine. I would check out your mouse and make sure everything is working great there. Have a good one.
Adam B.
04-27-2006 03:25 PM
04-28-2006 07:22 AM
04-28-2006 09:11 AM
How many lines are because I am not seeing the problem.
Regards
Ray Farmer
04-28-2006 11:09 AM
Hi Ray.
I have attached a seq where you can see the problem.
1.Open the seq
2. Edit the expression
3 Try to scroll the text with the mouse whell (dont press any other key on the mouse)
Then you should see that it start from the top when you scroll
Kind regards Thomas Bojer
04-28-2006 02:19 PM
04-29-2006 01:32 PM
Yes I see the problem, and I'm using TS 3.5.
Another problem I see with formatting your expresion like this, when you run your mouse over the description and you have the Tip highlighted enable, you dont see the bottom of the expression, unless off course you are using monitors that are greater than 17inches.
The plus side, it does make it easier to read.
regards
Ray Farmer
04-29-2006 01:45 PM
