NI TestStand
error code -17702 when debugging a dll from teststand
I want to debug a  *.dll which I have generated with LabWindows CVI with teststand. when I step then through the code of the *.dll and I return back into teststand the following error meassage occurde:
Details: Lost ActiveX connection to CVI. The CVI adapter will attempt to reconnect on next execution.
Error-Code: -17702; An error occurred accessing the CVI ActiveX automation server.
what is the problem?
rergards samuel
(4,089 Views)
Can you post the bit of code you are trying to debug?
Regards
Ray Farmer
Regards
Ray Farmer
(4,088 Views)
Ray,
I hope I have added all dlls.
another problem is, that I can't debug a Labwindows  "action" code module. I only can debug a Pass/fail test with lab windows adapter. so I use at the moment a pass fail step
regards
samuel
(4,085 Views)
Ray,
regards
samuel
(4,084 Views)
Hi samuel,
I was just hoping to see the source code that you are stepping through.
Regards
Ray
Regards
Ray Farmer
(4,084 Views)
Hi Ray,
is it possible to send the source code to your e mail adress?
thank you
regards samuel
(4,078 Views)
yeah, no problem.
Regards
Ray
Message Edited by Ray Farmer on 10-27-2005 03:15 PM
Regards
Ray Farmer
(4,071 Views)
