NI TestStand
dynamically change value of expression parameter
For the below variable setup  i wish to create an expression to dynamically get the values of the subcontainers.
- I tried something like :    value 1 = Evaluate("FileGlobals.MainContainer." + locals.currentSubContainer + ".value1")
How do i use evaluate to dynamically change which container is read ?
locals.currentSubContainer = "subContainer1"
... get value 1
... get value 2
locals.currentSubContainer = "subContainer2"
... get value 1
... get value 2
FileGlobals
    "MainContainer"
        "SubContainer1"
            "Value1"
            "Value2"
        "SubContainer2"
            "Value1"
            "Value2"
(2,924 Views)
Sounds like the property loader would be the best answer.....
Norbert
Expert: Geometry
(2,909 Views)
I don't need to control it externally.
I just need to use same subsequence to do same thing multiple times using different settings.
The "setting" should be dynamically changed based on a parameter "A", "B", "C". ect.
Something like:
http://digital.ni.com/public.nsf/allkb/42099F16F8DDEA4286256CBB005D1C96
i just can't make it work.
(2,902 Views)
Locals.currentFrequencies.F1 = Evaluate("fileglobals.CalibrationSettings." + parameters.currentFrequencySet + ".F1")
Gives me an error:
"A range is only valid inside an array subscript"
what does it mean, and why ?
(2,897 Views)
Can you attach a small example of what you exactly tried?
Norbert
Expert: Geometry
(2,896 Views)
Accepted by topic author NikolajEgeskovOstergaard
Solved it.
TS apparently checks if the dynamic value "exists" in the Variable list.
The parameter  was "empty" in my list hence it didn't work. If I gives the subsequence parameter a "dummy" value that actually exists but overwrite this before real use, it works.
(2,895 Views)
