07-29-2005 08:13 AM
07-29-2005 08:23 AM
Hi J,
Look at using the Property Loader step type. You can export the properties required from the steps you need to using Tools>>Import/Export properties... This will create a text file which you can then edit to provide alternative property values depening on the model.
Hope this helps,
Nick
07-29-2005 09:27 AM
Checkers,
I agree with Nick,
The property Loader is the way to go.
Check the following post.
It could help.
http://forums.ni.com/ni/board/message?board.id=330&message.id=7702#M7702
In your case you have to import your low and high limits using the property loader step before running your tests.
Regards.
07-29-2005 09:29 AM
