03-20-2007 01:10 PM
03-21-2007 11:33 AM
03-21-2007 12:00 PM
03-21-2007 12:53 PM
After further testing, it looks like the paths are stored in the TPJ file as relative paths even if you check the "Use Absolute Path" check box. I was able to manually edit this file and fix the problem, but it is updated with the relative paths after a build and then does not work.
al
03-21-2007 12:53 PM
03-21-2007 12:58 PM
03-21-2007 01:46 PM
03-21-2007 03:32 PM
James,
I finally got everything to work. I created a new TSW file and added all the files and paths. I can build it multiple times without it losing the path information. There is something strange about the TSW file that the consultant supllied. Maybe it has to do with moving everything from his machine to ours,
Thanks for all your help.
al
