07-28-2014 08:47 AM
every now & then our system Login-Users (users.ini) change also the station options change
can I simply copy the Cfg files directly in my deployment system
or shld I be religiously making the whole deplyment(Image+ Insatller) everytime
07-28-2014 09:10 AM
aparab,
If the only thing you want to restore is the Station Options, you can certainly just copy the users.ini and config files to the deployment machine. These files generally do not have extra dependencies, so it is not strictly necessary to use the Deployment Utility to transfer them. If you make larger changes, such as changing custom data type versions or changing test sequences, you would want to do a deployment to be sure all files are included and updated properly.
07-28-2014 09:15 AM
thanks Daniel
