06-19-2013 08:15 AM
Hello
I'm trying to delete all parameters of a sequence in run time within LabVIEW using the TS API method DeleteNthSubProperty with index=-1. It deletes all the parameters, but they are away forever... Is it possible to do it only in run-time? After the execution I would like to have the original parameters.
Madottati
06-20-2013 08:44 AM
Hi....
consider the attached example.
To open the files you need the Version TS2012 and LV2012SP1.
best regards
Bernhard
06-20-2013 08:45 AM
two times the sequnce files. Sry.
Now here are the vi
