I'm trying to run a TS+CVI code with debug. Everything was fine until I suddenly began to get error of not finding some files.
Warning: Cannot find program or file or library
Library: 'VXI Library'
Function Panel File: "c:\Program Files\national instruments\cvi70\bin\nivxi\vxi.lfp
There are other files as well....
The reason these files are not found is because I have changed (a while ago) the CVI directory name from 'cvi70' to 'cvi'.
The question is why is it looking for these files?
How to make the debugger look in my directory instead? (or not looking at all)
The last thing I did before this happened was running a test not in a debug mode until a run-time error happened and I got a window where I selected 'break'. I got a new CVI window that showed me where the error was.
Thanks for an urgent answer
Rafi
