I'm not sure which option of data logging to choose and what is the advantage/disadvantage of each one.
1) Which option to choose and why?
2) For not on-the-fly option, I noticed that the step 'Log To Database Callback' is activated. I could not figured out what happend when the on-the-fly is selected. The Help indicates that in this case 'Post Result callbacks' is called. Where do I find it?
3) I have a specific requirent that in 'Run Selected Step Using Single Pass' I like to insert the SN both in the report and in the database. Since the preUUT callback is not called in this mode I overcome it by getting the last UUT SN from within the code of my mainSequence (I read it from a file and have the operator approve it). Th
en, I added a statment step (in the sequentialModel) right after the MainSequence where I set 'Locals.UUT.SerialNumber'. With this mechanism, the SN is get into the database only if I don't use on-the-fly!!
My question is: Is it OK to do it the way I described it? Is there a better way?
Rafi
TS 3.0
