02-09-2006 11:49 PM
02-09-2006 11:49 PM
02-09-2006 11:51 PM
sorry, there seems to be some problem!!! with the KB
02-10-2006 09:38 AM
02-15-2006 10:02 AM
It took me sometime to go throughly with what you have told, so it took sometime for me...
I understood many things that you told me in your previous reply. But the only thing I didn't understand is can I change the look/format of the text report that is generated.
For eg, the numeric limit test (very simple and basic one) that I am doing looks like this in the report:
Numeric Limit Test: Passed
Measurement: 30.96
Limits:
Low: 10
Comparison Type: GT (>)
Module Time: 0.0114952
I want it to be something like:
Step Measurement Limits(low) Comparison Type Module Time
1 30.96 10 GT(>) 0.0114952
(I have made this manually.........)
For this which .seq file should I seak for or which .ini file has to be changed.... This will put all my problems down.
Thanks a lot for your help till now.
Regards
Sreedhar.
02-15-2006 12:12 PM
02-20-2006 04:31 AM - edited 02-20-2006 04:31 AM
""""Look in ModelStrings.ini for the existing header strings. You will be creating your own ini file though and you should copy the categories and tags into your custom ini file""""
I didn't create any <custom.ini> but copied the ModelStrings.ini to ......User\Model\TestStandModels and tried to modify that. Is that ok? Previously I did some changes in the same file for the header for eg: I replaced the "UUT Report" with "User Report" and it works pretty well. Now I feel there is not much to change, because I can change only the names there not the structure of the report... to be precise I also have the same problem like the one shown in the link below.
http://forums.ni.com/ni/board/message?board.id=330&message.id=5347&requireLogin=False
Message Edited by TSreedhar on 02-20-2006 04:32 AM
02-20-2006 10:12 AM
If you want to have a file of the same name in a different location, that's up to you. Personally, I would find it confusing. Also, you have to understand how TestStand handles all of these ini files. When TestStand starts, it first reads all of the files in the NI folder. It then reads in all of the files in the User folder. When it finds a duplicate in a User file, it uses that value instead of what was in the NI file. If you have a large file in which you've changed only a couple of items, you just making the startup of TestStand a little bit slower.
Yes, either TestStand is not calling that sequence or something is getting skipped. What are your report options? At the bottom is a selection for the report body. If you have DLL selected, it will not use PutOneResultInReport.seq.
I don't have a file called modelsupport.dll. I can only find modelsupport2.dll but in any case, usually files with different names are different in some way.
02-20-2006 11:11 AM
Modelsupport.dll was part of TestStand ver 1.0x.
Regards
Ray Farmer
02-20-2006 11:07 PM
Yeah, as expected, that particular seq was not getting executed. Instead of that, the "Get Step Result Body (DLL)" was getting executed. I simply asked the process model to skip that step and now I am getting inside "Get Step Result Body (Sequence)" . This was quite an excitement. Thanks for the same!!!
But after execution of the sequence, the output still remains almost the same: I want to have the transpose of what I am getting... I tried writing a labview program to transpose, but couldn't know how and where exactly to link it.
So, still primitive!!!
I want to know, what do the "Add Flagged Values" DLL (inside PutOneResultInReport.seq) does. I personally guess, it simply adds the 2-d array with the values. So I tried to incorporate the labview program in there, are my predictions correct???
As far as ModelSupport.dll is concerned, I found that my NI folder has ModelSupport2.dll and in user folder there is this ModelSupport.dll, I replaced it and its still working fine.
By the way, thanks Dennis for telling the importance of .ini files, it is really interesting to know the architecture and the way TS works.
