I am supporting a set of Teststand test programs.
I have been asked to alter the text report that is produced to be read by an existing script.
In order for the existing scripts to work the test data must be put into a txt file in a specific format.
I cloned the reportgen_txt.seq file and started to modify some of the sub sequences.
I was able to convert the header and footer sub sequences to conform to the scripts.
I am having trouble converting the body sub sequence.
I have narrowed this down to a DLL call that extracts the information from a container.
My problem is that I only want the raw data (numbers).
For example, I don't want the "Measurement:" or "Limits:" labels. Just the numbers.
What I want is: Pass/Fail, Value, Upper Limit, Lower Limit
