The error message is pretty clear.
Two possible reasons:
1. RTE (RunTime Engine) version is not the same as the development version of the VI. Either configure the LV Adapter for "Autodetect" (which is default) or the correct version which you used for development of the VI (e.g. LV 2013).
2. The VI is depending on subvis which cannot be found. Please note that the LV RTE does NOT know about vi.lib, user.lib and instr.lib. You have to create a LV source distribution for the VI in order to make the VI executable. Use the LV AppBuilder directly or via the TestStand Deployment Utility to create this package. LV AppBuilder is mandatory for this.
Norbert
Norbert
Expert: Geometry
