NI TestStand
configuration directory
I'm using TestStand 2010 (not SP1) on W7.  If I add the CfgLocation into the registry I can change the location of the Config files, however, I cannot change that location using the TestStand 2010 Configuration/Preferences method.  I would not mind if I was the only one working on this, but I have an entire team that will have to be accessing this and I'd rather not have several people be digging into the registry.
Please note that it works fine on TS 2013 on this same station.
Another problem I have is that whenever I switch from one TS version to another (2010/2012/2013) I have to use dcomcnfg to setup the permission of the NI TestStand AutoMgr tot he Launching User, otherwise I get errors on startup and don't have the CVI adapter in TestStand, which is a non-starter for me.
Carl
Message 11 of 11
(759 Views)
