I have a string in TestStand that contains letters and numbers; is there a way of comparing each character within the string to see whether it is either a [A..Z] or a [0..9]?
I dont understand the 65//A & 90//Z though; "//" is normally a comment; what is this function, it does not appear to be listed in my version of TestStand but works anyway?
You can put just 65. // is a comment. I put it so that you knew 65 was A. I'm just used to commenting code so if I ever come back I will know what it means.
Glad it worked.
jigg CTA, CLA testeract.com ~Will work for kudos and/or BBQ~
