I found that if I modify the TEST_UUTS string in ModelStrings.ini, I can change the text displayed in my entry point button.
[MODEL]
TEST_UUTS = "ATE TEST"
SINGLE_PASS= "DEBUG"
Similarly, I made changes to UIControlOperatorInterfaceStrings.ini to change what shows up in the tabs for my Top-Level VI in the TestStand 3.5 Operator Interface.
[TSUI_OI_MAIN_PANEL]
EXECUTION = "Test Execution"
SEQUENCE_FILE = "Test Sequence"
Now for my questions - one specific, one general
1) If I add a page (tab) to my tab control (say Quick BIT), I was told I could just create a contant in CustomStrings.ini and TestStand would grab the text out of that file.
QUICK_BIT = "Quick BIT"
How/where does it do that? I assume this constant (QUICK_BIT) would have to be unique and it would have to be specified in one of the properties dialog boxes somewhere?
2) In general, where does TestStand use these contants (say, for example, the one for TEST_UUTS)?
